2005 Yamaha F115TLRD gauge/alarm questions
natemoore
Master Chief Petty Officer
My new (used) Triumph 190 Bay has a Faria tachometer that is inoperative, a speedometer that is disconnected, and a fuel gauge that works. The prior owner wasn't aware of any over-temp or low oil pressure alarms on the motor or indicators in the instruments. I would like to monitor more parameters if it is possible, e.g., oil pressure, temperature, voltage, RPM, and whatever possible.
It there a simple way to replace the original gauges with better ones? Are there wiring harness connectors just waiting for the right instrument to be plugged in?
Thanks in advance,
Nate
99yam40
If you buy a Yamaha Tach kit for your motor it should just plug into connectors on motor as long as no one has cut t/modified them
natemoore
Analog with the oil and temp warning lights, fancy digital one, or either? What about the other gauges? Trim, voltage, etc.?
Thanks
99yam40
need to find a rigging guide for that motor to see what all will work.
Not sure if command or the C plus would work on that 2005
