2006 Ford 6-spd tranny - good or bad?
QuadManiac
Re: 2006 Ford 6-spd tranny - good or bad?
So how does one 'add a vane' other than in the design stage? Doesn't help me much.
mrfixitman40
Quad, does it hesitate going into reverse the first time in the morning. sounds alot like the solonoid pack causing the issue but try doing a transmission flush and see if it helps first
QuadManiac
What is involved in the solenoid pack replacement (rough time, cost) and I suppose it is a dealer only job, right?
I'm in San Diego, so it never gets too cold at night (if temperature is an issue) but i do notice that, at times, it takes perhaps a second or two to engage reverse once it has been selected. Just enough to make it seem a little longer than it should be.
mrfixitman40
the solonoid pack is pretty easy they are a little costly though it bolts up to the valve body . the price i can get it is a little over 200 but i believe list is about 400
QuadManiac
Sure beats the cost of rebuilidig the tranny, if you think that's what it is!
Thanks
