2006 Tahoe Q6 Dead at ignition switch
Status
Not open for further replies.
maddog2112
Long story short. Took boat out of storage, started it up and all seemed fine. I planned on rebuilding the carb I did so. Put the carb back on and absolutely nothing happening with ignition switch.. No beep no crank nothing. Battery shows 12.4 volts. All guages are dead. The only thing working is the horn. Trim tilt also working fine. All fuses in panel are checked good. Does anyone know where to find wiring diagrams for tahoe boats? Thanks in advance.
you will never find wiring schematics at the boat level. they do not exist
if you have a mercruiser, look up the mercruiser schematic. if you have a volvo, look up the volvo schematic
first, get a multi meter and a test light
second, clean all your connections from the battery to the motor and back
third, check the big circuit breaker at the motor
maddog2112
Thanks for the response. I do have the mercruiser manual, but it`s not specific to Tahoe. I didn`t touch anything electrical when removing my carb and reinstalling. I`ve never had an electrical problem on this boat. Since all gages are dead I was thinking coincidentally something died behind the dash.
alldodge
Check the 20 amp ignition fuse. This fuse feeds the key switch and is a red/purple wire
The carb should have a electric choke. The electric choke is feed by a purple wire and this wire if grounded will blow the 20 amp fuse/breaker what key is turned ON
maddog2112
Thanks for the info. It rained all day today but I will report once I find these fuses. Probably Monday. Thanks
maddog2112
Thanks for all the replies. I found the main 20 amp fuse blown and replaced it. Thanks.
markgee
Where was the fuse located? I'm having the same issue but can't find a 20A ignition fuse. Getting power at the breaker, but nothing when turning the key. Mine is a 5.0 MPI, so I'm not sure if the wiring is identical .
Status
