2007 4.3L TKS Mercruiser starts and runs then dies after about 30 minutes.
alldodge
Found a few kits just by searching on "Merc carb kit 866141001"
Complete rebuild kit is 817275Q05
Just the impeller kit is 47-43026Q06
Rcantu2
Alldodge would I need the whole impeller rebuilt kit or just the impeller?
alldodge
Your going to need new pump gaskets and shaft seal with the impeller. Remove the impeller and inspect the pump housing and seals. Then decide what you need
I like to get a complete pump an any new to me boat.
Rcantu2
Ok so now I replaced the fuel pump and the fuel water separator and now it won’t start. I do hear the pump running after I let go of the key for a few seconds. I guess a carb rebuild is next...
Rcantu2
This morning I went out and started the boat and it ran good for around 30 minutes and the problem came up......sputtering loss of power went from 650 rpms to about 400. This time it didn’t die just idled real low. When I would rev it up it would cough through the carb once or twice and then respond. ANY THOUGHTS.....I do have a carb kit on the way.
Rick Stephens
Kit the carb. Pay very close attention to making every passageway perfect. Take your time. Set the float height to spec.
Rcantu2
Thanks for the response....I have a kit on the way should be here Tuesday. I also ordered an impeller rebuild kit.
Rick Stephens
Follow the Mercruiser Service manual. They are very well detailed. Mercarb is dirt simple, good place to learn. Chase every port with a piece of wire or heavy fishing line. Spotless clean is the goal. Set float height carefully.
Rcantu2
So what number Manual do I need to rebuild the carb....serial number 1A084736...
Rcantu2
Today Installed the freshly rebuilt carb and new fuel lines as when I was removing the fuel line from the carb I stripped the brass fitting. The engine started after a couple of attempts as the bowl was empty. The throttle response was instant... awesome!! I let it run for more than 30 minutes on the muffs and it ran good but closer to the 40 minute mark. It started to backfire a little through the carb and when I throttled up it quit. I turned it off and tried firing it up again and it started right away. Any other ideas??? I think I’m going to take it out on the water and try it out.
alldodge
Agree, check timing
Should be at 10 BTDC with the Purple/White wire grounded which sets motor in base timing mode
