2007 50 HP ELPTO tilt/trim problem
LWD
Good morning!
I have a 2007 50 hp 2 stroke, and the tilt/trim motor has an issue. I was getting the boat ready to go fishing and the outboard was in the full down position, when I went to trim it up nothing happened. I took the engine cowl off and I could hear a click on the solenoid (I think that's what it's called), it did the same thing trying to trim down, except the other solenoid clicked. I manually raised the outboard, and while pressing the trim button on the outboard, I tapped on the trim motor (part # 827675A1) and it started working, and has been working since. So I figure the problem must be with the trim motor.
I don't know if this is related or not, but during the winter when temps didn't get higher than the teens I had to take a heat gun and warm the trim unit up before it would work. Maybe that put wear and tear on the motor itself?
I can buy the motor online for about a $100 or so, but I am wondering if the electric motor itself can be taken apart and cleaned up, reconditioned or whatever. Or if it's worth the effort and I should just foot the bill and buy a new motor.
Thanks in advance for anyone that offers advice!
alldodge
It can be taken apart, clean, lubed and work better , maybe
The tap on the motor may have made the motor work, but maybe the tapping also caused the relay or wire connection make a batter contact, don't know :noidea:
Suggest look real close, but you may need to work on the motor, but don't over look connections
LWD
AllDodge,
Once again, thank you very much for the reply!
That was a learning experience. I took the motor apart, a couple tablespoons of water came out of it when it separated. That would explain why it was freezing up in really cold weather. I left it apart a couple days to thoroughly dry out.
It definitely showed signs of wear and tear inside. I cleaned it up, put it back together and it's working, who knows how long it will be working is anybody's guess. Trim motors do get a lot of use. But now if it happens again, I'm much better prepared for it.
I've learned a lot from this forum, and really appreciate all the knowledge that is shared!
