2007 evinrude etec 40 hp
jrabbit
My motor runs smooth until it is revved up. It will not go on plane on the water. I have replaced spark plugs not sure what to do next. Sounds like it might be misfiring???? Not sure.
  • IMG_1048.mov
Crosbyman
being an ETEC look at the side LEDS on the EMM (CPU) when you run the engine. report findings top to bottom leds at
KEY ON....
Running.....
motor may be entering SAFE mode with max rpms around1800 due to a sensor fault code!!
to service ETEC you should get EV diagnostics to look for trouble codes. latest SW is ver. 5.9
suggest you consult with the ETEC OWNERS GROUP
download your manual look up back pages for trouble cause options
jrabbit
KEY ON....
Running.....
Ok I didn’t realize that showed issues. When it is running the injection/ignition light is glowing
Crosbyman
that should be #2 possible open/shorted injector or ignition coil
you need EV diagnostic to get the code to be specific or... start testing ohms values on inj and coil primaries.... & compare to specs. see manual
if all good electrically ohms wise..........inj. could be dirty/plugged up .
