2008 150 4 stroke has a sticky throttle.
lingcod
as the title says, the throttle is sticky on this motor. disconnected the cables and everything is smooth. hand operate the throttle and there is a little bit of resistance but once the cables are hooked back up the throttle controls are extremely hard to move. what gives? there is quite a bit of moving parts on the motor to operate the throttle but everything seems to be moving freely.
lingcod
BaileysBoat
Re: 2008 150 4 stroke has a sticky throttle.
Have you adjusted the throttle friction screw on the 703 control? The cables may be too long or to tight a radius.
