2008 180 BR 4.3L blower vent duct routing
buzzleo
For this 2008 180 BR 4.3L. how should the blower vent ducting be routed? Mine starts at the bottom port side of the engine then goes directly to the blower and is then connected to the vent out the back on the port side. There is also a piece of ducting about 2 feet long going from the front of the engine bay to the rear. It's on the port side also but is not connected on either end.
the short piece of duct should be on the bottom of your blower to grab all the fumes from the bottom of the bilge.
garbageguy
ensure the blower discharge hose doesn't have a low spot in it where material (most likely water) that could get in the vent, fill the low spot, and clog the blower's discharge
