Re: 2008 tahoe 215-tach
Medi, my reommendation is for the Soloas Rubex 4 blade aluminum prop in the 17" pith as it will let your motor turn right at maximum RPM of 4,800 and it will make your hole shot superb and you will be able to arry a muh greater load at higher speeds than the prop you have now. It lifts the stern and has enough blade surfae area to hold the stern up and pull up skiers effortlessly.
It is available at Iboats and here is the information for it.
Price: $126.98
You Save: $30.97
Compare: $157.95
Discount: 19.7% Off
Add RUBEX 4 Aluminum Propeller Prop: 9513-145-17 Hub: RBX-102 To Your Cart
Propeller Specifications:
SKU
rop #9513-145-17Hub #RBX-102
Manufacturer: Solas
Brand: RUBEX 4
Material: Aluminum
Diameter: 14 - 1/2?
Pitch: 17?
Blades: 4
Rotation: Standard (Clockwise)
Usually Ships Within: 1 Business D
H
