First, this site has helped me with my previous boat and I am thankful for a community of experienced boaters
I have recently bought a 97 Rinker Captiva 232. The boat was repowered by the previous owner in 2010 with a 5.7 carb GM 350 from Michigan Motorz.
Here's the issue. The boat ran great out on the lake for about an hour at 3k to 3500 rpms. As I was coming back to dock through a no wake zone, the engine started to sputter and then died. Initially I was able to get it to turn back over and idle through for another couple hundred yards before this happened again.
My initial first thoughts, bad fuel filter, vapor lock, bad fuel pump, bad fuel pressure/oil pressure safety switch (couldn't merc figure something else out for that?).
Solutions thus far: I have ripped the entire fuel system apart. I am able suck gas through line. (Yes, the taste of fuel in my mouth is awesome). I have replaced the fuel filter, the pressure safety switch with #87-864252A01 which apparently replaces 87-805024, which was probably less expensive
I have eliminated the fuel filter, the check valve, and tried running gas lines straight through pump right into carb. The motor would turn, run, and after a minute or two at idle, would stall back out. Oil pressure on dash reads 40psi. I have ripped all spark plugs and tested compression. 155 in each cylinder. Oil level seems good. I really think at this point it is the fuel pump or carb. When I open throttle on carb I do not get a mist. Initially while it was running last night it seemed to be dripping fuel into the intake. Then it just became bone dry. I did notice some water droplets on top of one of the butterflies.
Conditions as of last night. After a bottle of wine and listening to this pos start, run for a couple minutes, and then stall, then not run at all unless I dripped a little gas down into the throat. I decided to rip the carb off which is an Edelbrock 1409 model. If someone can add their expertise in tuning this, testing this, etc., I would really appreciate that
I am convinced this is a fuel delivery issue. It is really upsetting me. Though the fuel pump sounds like it runs, it sounds like crap. Anyone have a suggestion for a replacement. I have a carter 4-7 psi electronic pump on there now. I'm ready to replace it even though it seems to pump gas. Maybe someone has a way to test this without blowing myself up? Seemed dangerous and odd to direct line it. I did bypass the safety switch briefly, I can hear it run and it seems to push fuel through. If someone has a cross reference sheet for parts and supplies, that would be awesome!!!
I am banging my head against everything!:facepalm:
THANK YOU IN ADVANCE BOATING COMMUNITY!!!
Ryan Wolf
Ryan Wolf
