2011 Yamaha outboard 40HP shuts down after 30 minutes
thehalfwit
2011 Yamaha outboard 40HP shuts down after 30 minutes @ 2800 rpm. After waiting 15 min. it fire's up and runs fine for another 30 minutes, then shuts down again. Any suggestions?
Thank You!
99yam40
is it shutting off completely or just reducing RPMs?
do you have overheat or low oil pressure indicators that show up when this happens?
99yam40
I guess this is a F40 with fuel injection.
low fuel level in VST causing the pump to try pumping air instead of fuel would shut the motor down like you turned off the switch.
lift pump sucking air, tank vent plugged causing a vacuum to form in tank, restricted pick-up tube in tank, return line dumping too much fuel back.
Might monitor the fuel pressure to the VST and rail pressure to give some indication if the problem is fuel related.
did you try pumping the primer bulb to see if that helped any and also may indicate if the VST is running out of fuel if you have tp pump a bunch to get it firm again
thehalfwit
I have not, but will next spring. Thank you!
