2012 VP 300 C-A Exhaust manifolds getting too hot - DTC 441 & 442
muc
"Retired" Association of Marine Technicians...
Would my IR temp be as good as using the Diacom? I have to take my laptop into the cabin to be able to read it. Kind of a PIA. IR temp gun is a lot easier.
yes
Donald0039
Would the coolant temp dash gauge show the same or close to the same temp as the IR temperature gun reading the exhaust manifold?
muc
Normally they are close. But one of the screen shots of Diacom you posted showed engine coolant temp 85° and EMWT 224°. So you will need to monitor where the problem is.
Donald0039
Well running the engine at 1500 rpm for 15 minutes seems to have purged the air out of the system. Ran the engine today in the water for 20 min at 1500 RPM and no overheating. Both exhaust manifolds stayed around 170F.
Of course the directions on the expansion tank say exactly what needs to be done but they were in small print, hard for me to read.
So problem is resolved.
muc
Great!
Thanks for the follow up ---- it's sure to help others.
Donald0039
I finally got the workshop manuals for my engine. I ordered them from Volvo Penta and they were shipped from Sweden. You would think Volvo Penta would stock them in the USA.
The Seloc manual is worthless compared to the Volvo Penta workshop manuals.
mvn
Been following this topic since the beginning and have a comment regarding the availability of Volvo VCS coolant. My V6-280-M is also a closed system and I wanted to get some Volvo coolant to keep on hand to top up the expansion tank just in case. I have not been able to find any.
I passed by a Volvo heavy equipment dealership one day and stopped in to visit their parts desk. Low and behold, they carry yellow Volvo VCS coolant!
In my search, Fleetguard by Cummins also carries an equivalent call ES Compleat OAT (see attached).
Mark
  • LT36262 Coolant Cross Reference Brochure NEW.pdf
Donald0039
Mark
Yes I recently found out about Fleetguard yellow OAT coolant as a direct replacement for VP VCS. That means (I think) you can top off with Fleetguard yellow OAT.
What is your winterization plan?
mvn
1. Stabilized fuel
2. Changed engine oil and filter cartridge.
3. Ran 1 gal of 50:1 2-stroke premixed fuel to lubricate fuel pumps and injectors.
4. Changed fuel filter.
5. Changed sterndrive gear oil.
6. Drained raw water and flushed raw water side with pink antifreeze.
7. Lowered Drive to full down position.
8. Greased prop shaft splines,
9. Removed batteries and placed on battery tenders.
10. Acid washed hull then washed and waxed.
11. Detailed interior.
12. Drained bilge including tray under engine.
13. Wrapped boat with storage cover and poly tarp.
14. Patiently waiting for spring.
Mark
1. Stabilized fuel
Mark
What does this have to do with the OPs thread? Please do not hijack threads
Donald0039
1. Stabilized fuel
Mark
Do you use an electric pump to pump in the pink antifreeze?
mvn
I gravity feed the pink into the engine bay flush connector/hose with the engine at idle with the Quick Drain closed.
Afterwards, I open up the Quick Drain and drain everything out.
Mark
