2015 Mercruiser 4.3 EFI issues.
Helping my friend get his boat he purchased last year sea worthy. He had it out a few times, both ending in issues. First the gear oil resevoir leaked and set of an alarm. Would this cause the engine to go into limp mode! New reservoir installed.
Second issue, low voltage. Diagnosed as alternator, most likely damaged when the gear oil leaked and coated the alternator. Replaced alternator. Have not yet run engine to test. Would the engine run poorly or quit, absent a solid 12+ volts? I'm wondering if he ran the battery down (inop alternator) and the ECM/PCM etc didnt like low voltage?
Third issue, we changed the oil, (suction pump) and the first quart was all water. 4+quarts of oil came out. So, where did the water come from? Last time the boat was out, the engine quit (low voltage?). Engine would crank, but not start. I'm wondering if the water came in the exhaust from the rear wake via absent exhaust baffles? Why no restart?
I wasn't there for any of this, so it's the best explanation I got / can give. The boat is in Phoenix soma frozen and cracked block probably isn't the reason for the water.
Thanks for the help
alldodge
Could use the motor serial number to verify, but being a 2015 it can go into power reduction (limp mode) if voltage is low. When voltage drops the PCM doesn't know what is wrong because so many things are showing problems
Low gear lube sounds an alarm and sets a code
Water in the oil could come from water going up the exhaust, but if it did that it would also hydro lock the motor. Most likely this is either a crack in the block or intake.
As to why no restart we will need more info
Start first by measuring the Battery voltage and see if it's close to 12.7V when not on a Bat charger
Assuming this is a MPI check fuel pressure at the rail, should be 43 psi with key on
Dump the fuel filter contents into a clear container to see if there is only clean gas
ESGWheel
Cracked heads / block / blown head gasket can also come from overheating. In addition to the above, also suggest to run a basic mechanical evaluation on the motor prior to trying to restart > a compression test.
And even prior to that, suggest pulling off the valve covers looking to see if that oil in the water has tuned to a milky goo covering it all. This will provide an indication of how long that water has been around. If it’s a milkshake in there, then its everywhere and more then likely means a rebuild.
If all seems to be good, ensure the other basic maintenance is done as well, like the impeller prior to restarting. There are lots of posts on this forum regarding these preseason items.
Good luck!
Thanks for the reply. We did a new impeller and gear lube. I've got a fuel pressure tester so I'll check press at the rail. i Haven't been back over to help him but will try this week. The boat has been sitting for 9 months so the oil that came out of the pan had ample time to separate. No Hydro lock according to the owner.
Lou C
Agreed with previous points made, if the boat was never in a freezing climate condition as you say then the more common ways for water to get in the oil is up the exhaust or overheating. Again as noted if up the exhaust it likely would have caused an obvious hydro lock with cyls full of water, overheating depending on how severe would damage the head gasket first then if it went to a more severe overheat cracked cyl heads are also a possibility. Both can let water into cyls and into the oil. A Qt of water in the motor oil is a lot. What concerns me is how long the water was in the oil. Ideally you want to get it out as soon as you know there’s been water in the oil & cyls. The fact that it sat there that long makes the possibility of a full rebuild more likely that just being able to go in and change head gaskets or even cyl heads. Unfortunately parts prices for these Merc built inboards are much higher than for the older GM marine engines.
Before taking things apart see if you can air pressure test the cooling passages.
Just thinking out loud here, would an exhaust manifold jacket full of water with an internal crack leak that much water, over months down the manifold and into whichever exhaust valve was open? There is a central knob (blue) to drain the cooling jacket down, which was not done prior to sitting. I opened the and drained it. Going over there tomorrow if it works out.
Scott06
yes that is how exhaust manifold maintenance (or lack there of) can ruin a engine.
Is there any way the boat wasn't covered and water could have gotten down the intake? often times folks remove the flame arrestor cover when working on it... its there to keep water out of the intake and off the distributor.
per google the most recent freeze in PHX was in 2019 so freeze damage would be unlikely unless it was freeze damaged before your friend bought it elsewhere
Take the plugs out see if you see water in the combustion chambers. you can remove an exhaust elbow to see if there are traces of water in exhaust, this should have dry joint manifolds so would think that would not be a leak source if used in fresh water.
Sorry for the delay in getting back to this thread. Made it over to the boat.
Throttle body was covered with the arrestor assembly, and engine cover and boat cover in place at all times so no water intrusion that way. I took a socket and my long handle ratchet and turned the engine over by hand using the damper bolt. The engine turned over fine. I did so slowly and listened and nothing noted. I hooked up the muffs and cranked the engine over with the kill switch off (No fuel pump, ignition etc). Turned over fine and no unusual noises noted. Flipped kill switch to run and cycled key on and noted fuel pump prime cycle. Did this 4-5 times as I changed the fuel filter and did not fill it with fuel.
Engine cranked and felt as though the timing was way off. Had a hard stop and a caugh out the throttle body at one point. Engine never fired off or even attempted to. Engine turns over normal with kill switch in off position.
Bad gas? Water in gas? Crank trigger?
Having a mobile marine mechanic come out next week.
alldodge
The kill switch keeps power from going to the motor so nothing will work like fuel pump and ignition, but it will still crank
No fuel and pump runs then look at antisiphon valve on the tank, might be clogged. Can also run the boat from a gas can with hose going to the filter
ESGWheel
While its good the engine turns over, the idea of the water in the oil still is an open issue. Now that you know the spark arrestor, etc were in place, eliminating that potential source of water intrusion this red flag still exists. Did you take off the valve cover to see if a long-standing issue (post #3)?
Regardless, to run need three basic ingredients: compression, spark & fuel. Since the engine turns over and given the water intrusion may be from bad head gasket or cracks, suggest starting with a compression check.
If you have good compression and there is no milkshake under the valve cover, it is a very positive sign the mechanical aspects of the motor are healthy.
Next use a fuel pressure gauge and determine fuel rail pressure. If good, then check for spark.
One of these (compression, fuel or spark) will reveal itself as ‘bad’ and with that info, tackle that issue.
