- Jul 23, 2011
- 52,195
I did enjoy the basics of the 1990's Formula vs. today's boats.
And make sure you have the latest Diacom version too (3.3 dropped just recently)It also seems that if you are into 'I.T.' you can't get away from it even when retired. I probably should do the software upgrade on the vesselview4.
Installed version is - 3.0.43.349
Latest Version is - 5.0.43.579
Yes, I just checked the pricing on the cable adapter that I would need . . . $249 !!!And make sure you have the latest Diacom version too (3.3 dropped just recently)
Chris...
Ouch!Yes, I just checked the pricing on the cable adapter that I would need . . . $249 !!!
It's a freebie....... Do you know if the 3.3 upgrade is free (or minimal cost) if I have the 2.9 version?
The adapter is what costs . . . I could probably upgrade the software now, since it is free. I am wondering if there is a generic equivalent to the adapter cable . . . at a much lower cost.Maybe just get the adapter first and see if it supplies enough info to fix the issues, before upgrading to 3.3
Doesnt the trim sender just change resitance as it moves i dont think there is voltage on it , or is it a different setup on these fly by wire newer boats?SOLVED !!!
It was the trim sender. Once I disconnected it the low voltage went away. The starboard trim sender has been faulty since before I bought the boat, but there was not enough time (motivation) to fix it before launching.
The low voltage warning was not present when test running the engine on the trailer (i.e. on land). I attributed it to being on shore power, but that was not the case. My solar charging system has all of the batteries sitting at 13.7 volts, and the warning was still present. As soon as I disconnected the trim sender, the warning went away. My thoughts are that on land the trim sender was dry. In the water, it apparently has a leak and is full of water, looking like a short (or low impedance) circuit.
It seems that where the PCM is sensing its supply low voltage, is also where the trim sender connects. If the sender is faulty, it can drag down the voltage in that area of the circuit. No more beeps . . .
Didnt know that thanks is that true for the older carbed models like i haveAll sensors work off a single 5V reference produced by the ECM. Any sensor that draws to much current causes all kinds of issues
(Newer) digital sender versus older analogue...Doesnt the trim sender just change resitance as it moves i dont think there is voltage on it , or is it a different setup on these fly by wire newer boats?
Yeah I’m still playing vinyl…(Newer) digital sender versus older analogue...
You get full range on vinyl. They remix digital to clip the highs and lows because blue tooth can't handle full range audio.Yeah I’m still playing vinyl…
I thought you'd still be chiselling out stone tablets.You get full range on vinyl. They remix digital to clip the highs and lows because blue tooth can't handle full range audio.
Long live vinyl and tube amps
Nah ..using a stick in a wax tablet. (Tabula)I thought you'd still be chiselling out stone tablets.
Chris.....
