- Jul 18, 2011
- 19,007
I survived the dentist and PT appointments and will be back at the boat tomorrow. Plan for the day is . . .
1) Try some new fuses
2) Check resistance to battery ground for the 3 ground pins on the connector(s)
3) See if I can verify that the Pin 'A4' stays at battery voltage with the PCM powered.
4) Maybe swap out the battery.
I also think I should upgrade the VesselView to the latest patch level, while I got 'the hood up'.
