2018 Mercury 150 EFI hard to start hot
Jeff J
Motor has been running great and starts easy cold but go for a restart after it is warmed up and it repeatedly fires and dies. I don’t see anything in the service manual covering the issue. It can be started by giving it a little throttle but something isn’t right for that to be a requirement on any EFI engine.
alldodge
Don't know the motor but I might look at the IAC and see if it needs cleaning
Jeff J
That was the second thing I tried before asking even though it usually runs like crap when the IAC needs cleaned. For some reason, of the 3 motors like this I care for, this is the only one that ever gives me trouble with the IAC getting dirty. The first thing I did was change the fuel filter even though it didn’t give any of the normal dirty filter signs. I have not checked the fuel rail filter or pulled any injectors. I would expect different problems with those too. Hard to start hot whether on the lake or idling at the shop sitting in the tank.
QBhoy
Have you ever removed the cleanable/serviceable fuel filter strainer in the fuel rail ?
How’s the throttle position sensor ? You can test this, as per the manual.
Could be the coil packs too. They can cause issue with varying heat conditions.
