2018 Yamaha 115hp Spark Issue
frustratedboater
I have a friends 2018 Yamaha 115hp 4-stroke that was running very rough and sporadic idle. I shut it down and conducted a spark test to see if any cylinders were dropping. Fuel is good and pumping fuel well. I tested the ignition and I didn't see any ignition spark. Went through he typical- kill switch is operational, neutral safety at the engine is making contact.
I Ohms tested the pulsor coil and got a 520 reading and believe it should be around 360 (+/- 72). Is this correct"
99yam40
how did you check spark?
Are you not getting spart to any of the plugs or just some of the plugs?
you need to monitor the inputs to the CDI and the out puts to find out what is going on.
I do not have a manual for your motor,
do you so you can look at the specs
frustratedboater
I appreciate the reply!
I do have a marine 'quality' spark tester (it has an acrylic body and 8 ports). I just grounded to the block and plugged from top to bottom on one side. I did not see any spark on either of the plugs. Prior to that it was running choppy and seemed like it was dropping a few cylinders. The guy said that the motor was shaking violently on the water and would bog back down at 1/2 throttle.
The monitoring the inputs... may be a little above my abilities. Since it is a friend of mine I do not have that year manual. I only have a 95' to 04' Yam manual.. By chance, would the procedure be in a 04' to 2014 Suzuki manual? Sorry, not my wheel house..
99yam40
I have no idea, since I never owned a 4 stroke Yam
but I would think it would not be the same as a suzuki as far as specs but I could be wrong.
kills switch should take out all spark not just some
there should be stuff to charge up things and others to tell it when to fire the plugs
