2020 Nascar - Bristol - A Last, A First and A Last
WIMUSKY
Any truth about Hailie Deegan, ARCA, being the next big deal?
GA_Boater
She hasn't won an ARCA race, but has three K&N wins in '18 and '19. She is an aggressive driver, even against her own teammates and seems to be mouthy. Harvick has given her high praise. Maybe?
WIMUSKY
Mouthy goes with the territory. Especially for a gal in a guys sport. She needs to be able to keep the boyz in check....
GA_Boater
2nd coming of Danica? Who knows.
Reminder - iFL roster locks at 7:40 ET this evening.
GA_Boater
3 to the rear for inspection failures;
It was a body issue on first time through tech and then when that was fixed, rear alignment issue on second time through tech for the KyBusch, Hamlin and Jones cars, all which will drop to the rear on pace laps.
You have until 7:40 to change your rosters if starting in back at Bristol with 500 laps means anything.
GA_Boater
Engines fired and warming up. Competition caution lap 30.
GA_Boater
Caution for Stenhouse doing a major wall scrape. JJ helped.
GA_Boater
Matt D a Redick took only 2 tires and will lead the restart. Keso is 3rd..
GA_Boater
Keso leading, Elliott has worked up to 2nd. TWT is inside the top 10 after starting in back. 24 to go in heat 1.
GA_Boater
Elliott win the 1st heat. TWT tried, but lapped cars held him up.
WIMUSKY
I like your PSA comment, I'll take it! So is Jimmie out unless he wins?
GA_Boater
Lap 200 - Elliott keeping on TWT and drops back a bit. then closes again.
GA_Boater
Harvick up to 2nd behind TWT. Elliott 3rd.
Hamlin ran into back of Truex and the front is mashed - Stays green. 18 to go.
