20hp Mercury with no neutral?
Status
Not open for further replies.
boatmotorcanada
@johnrolf if you're still around.
I have the same exact problem/ did u figure it out?
On front bracket label on my 1971 mercury model 200 starting instruction.
-Says to put shift lever in neutral
-move till handle to start and start motor.
Issue #1
- tiller handle will not twist to start when the shift lever is in neutral.
Issue #2
- tiller handle will twist to start only when shift lever in forward or reverse and motor will start no problem at all with going in rev /neutral / forward.!
*** cam in foot is well aligned because I set cam in neutral and shift lever in neutral when install foot.
jbcurt00
Issue #1
Issue #2
Nearly 19yrs ago, Johnny might have replied.
Not likely to now
Closed
Status
