HT32BSX115
- Dec 8, 2005
- 10,083
Re: 211 Liberator prop question
Hmm,
Didn't see the fact that it's a closed cooled engine!
That would make it "better" but it's still a salt-water drive. I would want to inspect the drive closely for corrosion and a lot would depend on if it was moored in the water or on a trailer.
That combination would have been my choice if it was available back when I was looking.
With 2400 hours on it I would be looking at rebuilding the engine AND drive so I would be offering based on that.
2400 hours doesn't mean the engine is "shot" by any means..........but if it's not been properly taken care of, then all bets are off.....
I don't know what it means when a Bravo III has 2400 hours on it. He doesn't say what year model (or SER #) it is. but that's out of a boat that got a LOT of use!!
If the engine has good oil pressure and compression, it was probably well taken care of.....
That drive is probably a 2.00:1 ratio.
That 383 will do 5000 RPM I think and is rated at 320 Prop HP, so from: Prop Slip Calculator
Using 28p props, 2.00:1 ratio, 5000 RPM, 10% slip you would do 59mph
You also would probably get out of the hole a tad quicker than mine because that engine and drive combo is a little lighter.
( I think an ideal 211 LIB engine would be an all aluminum 383, with aluminum heads, manifolds and risers.)
You would shave nearly 300 lbs off the back of that boat! BIG BUX
Hmm,
Wow, if that 383/bravo3 was closer I would be dealing on it right now! For a stock bolt in mercruiser setup that should be capable of 60 mph in my boat, with a huge gain in out of the hole I would think.
