225 Johnson oil in fuel
bighh7
Ive got a 225 Johnson and am getting oil in my racor , the fuel is clean in the tank but it seems to be feeding oil into my fuel line and going back to the racor , any ideas ?
boobie
Re: 225 Johnson oil in fuel
Is this after the mtr has been sitting for some time or what?? Model # would also help.
bighh7
Theowner runs the boat often , but lets say yessitting for a while . This is only on the stb engine and not the port one .
boobie
Check the fill cap on the oil tank to make sure it's venting. If the oil tank builds up pressure when sitting it can cause this prob.
sschefer
I'm not a JohnyRude guy but on the Mercs there's a check valve in the fuel line before the pump. Might be one on yours too. Check the manual.
boobie
JohnyRudes don't have them.
bighh7
Thanks for the advise , yes the cap was not venting . Thanks for the tip
boobie
Thanks for the come back. Good to know you found the prob.
