225 No power under load
mcfly99
My 93 225 TXRR has been sitting for about 18 months. The engine ran perfect up until the day I thought I would do some preventative maintenance. The head gaskets were swelling and after seeing a friend spent $1,500 on a rebuilt power head (water intrusion = blown piston) I thought I would be ahead of the game. Long story short, due to breaking off the head bolts, then illness in my family the boat has just sat until now. <br /><br />I’ve drained all the fuel from the boat, replaced the fuel / water separator and drained the fuel from the fuel filter. I’ve replaced the following items: Head gaskets; Head Cover gaskets; Anodes on the block; Inner & Outer exhaust gaskets; Thermostats; Pressure Control Valve; Water Pump; Lower unit gear oil; Fuel Feed assembly (check valve); Plugs; Primer bulb.<br /><br />The engine starts fine, idles @ 700 rpm with the muffs on and will rev up to 5,000 rpm’s with no load in the driveway. I first ran the engine from a separate tank to ensure I had good fresh gas.. Seemed ok with the spare tank and with the new gas in the boat tank in the driveway with the muffs on. Compression test (no leak test run) when warm 123lbs per cylinder. In the water it runs ruff (not missing) and will not go over 1800 rpm’s. When I got home I pulled the plugs and they looked fine, although plugs from the lower two cylinders (5 &6?) looked different, almost like they may not be getting as much fuel as they were cleaner that the others. I checked the fuel filter and it was fine too.. Re-ran compression test, still @ 123.. I have not touched the carbs; fuel pumps; or the yamalube oil in the tank.. How do I diagnose this, where should I start? I did not want to just blindly start.. Any guidance you can provide in narrowing this down?
rodbolt
Re: 225 No power under load
after 18 months of sitting its time to clean the carbs and replace the fuel pumps. replace the filter in the remote tank and drain the water trap on the engine oil tank as well. try not to do so much no load revving. the wristpins and rod bearings dont like it much.
mcfly99
Originally posted by rodbolt:<br /> after 18 months of sitting its time to clean the carbs and replace the fuel pumps. replace the filter in the remote tank and drain the water trap on the engine oil tank as well. try not to do so much no load revving. the wristpins and rod bearings dont like it much.
Thanks for the advice. I will get two new fuel pumps and install them and clean the water trap on the engine oil. As for the carbs, this may sound stupid but I’m gonna ask to be sure… Do I take them off and disassemble & clean or get some carb cleaner (spray) and clean them while it’s running?
mcfly99
Just wanted to follow up.<br /><br />Thanks Rodbolt, Thanks Ray, I followed your advice and replaced both fuel pumps.. Disassembled and cleaned all the carbs.. (Was an easy fix) I think my engine runs better now than it ever did.
