I have an 1985 25hp mercury/tiller handle/ with a portable 6 gal fuel tank.
I took it out and primed it, started it. It idled fine. At full throttle it would lose prime. I would simply squeeze the primer bulb and it would pick back up. It would run fine at half throttle.
I took it back out the other day and same thing. Except this time I could not get it to prime at all. Now it won't even start.
I bought a new tank, fuel line with fittings, and primer bulb. I cleaned the fuel filter and the fitting that the fuel line plugs into on the motor. Oh, and the filter/bowl was almost empty when I took it apart.
It won't prime one single bit. I can't even get it to get fuel into the filter/bowl. I even turned the motor over some to see if it would pull some fuel into the filter/bowl but nothing.
One thing is that the fuel fitting that is on the motor, the pin inside it is very corroded. I cleaned it up the best I could. As far as I can tell, it functions like it should.
Any suggestions? I'm no mechanic unless it's a simple fix. I talked to a mechanic and he said that the fuel pump may be bad. But this was when it was just losing prime when running at full throttle.
Bryan.....
Bryan.....
