25 yamaha not spraying water
duckboat1
I have a 2006 25 HP yamaha 2 stroke with less than 10 hours on it. I went duck hunting with it and got in some mucky mud and shut the motor off. When i got the boat out of that stuff and restarted it, there was no water coming out of the pee hole. Where do I start to repair this. Is it possible that the pee hole is plugged? Or is it possible that the water pump is shot or even mud stopping up the cooling water in the head? Thanks.
deejaycee_2000
Re: 25 yamaha not spraying water
All is possible .... firstly take off the thermostat and put the hose in there and give it a good spray, then start the motor and take a thin wire and wiggle in pee hole while motor is running (on muffs) if all else fails, it is time to drop the lower unit and see what the impeller looks like .....
JUSTINTIME
sounds like you got mud in there
time to backflush
