270 Outdrive Impact Release
iracer99
I have a AQ130/270 which I've got working pretty well. I am trying to find out if I should be able to lift the drive by hand while in neutral or forward? It locks down fine, and releases fine with the power lift, but I cannot lift it by hand. Does it take some greater impact force to overcome the pawls?
Tommy
kenny nunez
Most times it will not release by trying to lift it. While it is lifted spray all the moving parts and try to move them with channel lock pliers . Motor cycle chain oil would stay on the moving parts. As long as it does not release in reverse it should be in good condition.
djhinca
Normal operation of the reverse interlock mechanism is that when the drive is in neutral or forward and the lift jack shaft is in its fully up position, the outdrive must undergo a sizable backward force to overcome the spring latches that secure it to the locating pin (running aground, etc..). In reverse, the spring-latches are locked in the fully engaged position, preventing the drive from tilting upward. When the jack shaft of the lift is lowered, it contacts the yoke and holds the interlock's thrust rod from rising into the yoke, thus releasing the spring latches as the drive is raised. If the electromechanical lift raises/lowers your drive as expected, it sounds as if your unit is working as intended..
PiratePast40
Reach in between the outdrive and transom and pull down on the latch to release the pawls. Then lift up.
