nashwinter123
- Apr 5, 2009
- 82
i do not understand what could be the issue with the carb on this 28 spl evinrude. i have rebuilt the carb twice and it will not stop flooding. it floods as soon as fuel enters it. i have played with the float hight over a hundred times with 4 different floats all from the same size carb. when the carb is flipped upside down it does not flood. i have used all the rebuild kits parts from the 28 on a carb off of a 70 hp and it seals it and operates perfectly fine. the problem is, is the drop in hp and running to lean. what could be wrong with this carb.
