28' Marinette (Aluminum) - Restoration
Rich11304
Re: 28' Marinette (Aluminum) - Restoration
I'm going to try to post a video of my son peeing the paint, after we applied the West Marine Paint Removal, covered with a thin drop cloth and taped around it> we let it sit for the night.
Rich11304
[video]http://www.slickpic.com/album/1972Marinettealuminum28WithFlyBridgeRestoration#69 87439[/video]
Thalasso
That blue in the cabin must have been the color of choice back then. The guy that has one a feww slips done from me has the same color below. He had the boat painted a navy blue.(urethane)
Jeep Man
What a nice find Rich. Paint seems to be coming off quite well. Hoping the rest of the re-build goes as well. Definitely following along on this one.
Rich11304
We started cleaning the cabin. All the blue cushion's are in fairly good shape, not perfect by any means. It's a good thing my favorite color is blue. I'll post some pictures on the cushion shortly. I also found the owner's manual and in the back it writes: (hand writing from one of the owners: " under no condition should you have the bottom sandblasted, there is a factory film that should not be sandblasted off." Inwas planning on having the bottom sandblasted after we finished removing paint on the topside.
Rich11304
For those who have just joined. Thank you. I'm going to need a lot of help. Comments and suggestions are always welcome.
Gibbles
I think you will need to do some blasting around/in the corrosion pre welding.
If it has a hardcoat anodizing you will want to tread lightly...
mr300z87
What a cool project. I am a glasser guy so I will not have much to add other than encouragement. Since I am a Mopar fan and it kills me to have to work on these GM I/O engines but that is the cost of boating. I would love to see those 318s rebuilt as they are some of the best engines the US auto industry ever made.
Rich11304
Mr300z87 - My marine mechanic Dieter has been advocating for same and I hear you as well. Parts for Chrysler 318 in this area are very rare and for the same weight the 350's have more hp and torque/ We might be able to rebuilt them to increase the torque. Any suggestion?
Bamaman1
You are indeed a brave man. The hull is one thing, but having to address two engines and transmissions is another issue.
We still see some Marinettes on the Tennessee River, as aluminum boats last just about forever in fresh water. Unfortunately, any aluminum boat kept in salt water has to be properly painted and protected with anodes.
One great thing about stripping an aluminum boat is that you don't have to rush and prime it--as they're not going to rust. And hopefully there are experts available to advise you on refurbishing the hull and patching the bad places. I hope you have a qualified welder that can TIG weld any patches.
FYI: NAPA also has a great acid based metal cleaner that is sprayed on with a yard sprayer, and rinsed with water after 5 minutes. All the pontoon boat owners use the stuff. There are also other aluminum cleaners available at boat yards.
The 318 straight inboards were in many of the houseboats built in the 1980's. I would think you could find some marine salvage yards with fresh water 318's that are rebuildable. Many of the houseboats were built in Tennessee and Kentucky, and that would be a good place to look for salvage engines. While you're at it, you also want the tranny's to be at 100%.
It would be so much easier if you stuck to 318's. If you had to change brands, you'd do best to buy a whole donor boat with a matching pair of inboards and switch the motors over. Other options would be to switchover to inboard outboards or reinforce the rear end and switch to a pair of big 4 stroke outboards on aluminum external motor mounts.
Remember that any wood that needs replaced needs to be nothing but marine plywood. After all of your hard work, I hope you have a way to get this boat out of the water--if it's to remain in salt water.
Quick3201
I love people with a vision. Am I wrong, or has the transom been completely eaten through?
Good luck.
Plenty of 318's and 360's in salvage yards. is one of your motor a reverse rotation? if so, rebuilding that one would be a bit more, however you already have the marine specific parts.
Quick3201
Good luck.
mr300z87
Rich, I would suggest you pick up copy of or visit mopar muscle magazine web site plenty of mopar specific suppliers there. Actually mopar muscle mag office is in florida. A well built 318 can make close to 300 hp although you need to be careful with cam selection to avoid reversion. An upgrade would be to find a couple of 360s which share there platform with the 318, similarly to the 305(junk IMHO) and 350 GM engines. All the marine specific hardware should bolt right to the 360. Another way to go would be to upgrade the 318 heads to magnum style 92 and newer although there would be some hurdles to over come.
Unfortunately most of my mopar engine knowledge is auto based, and even though the base engines are the same the tuning (ie cam spec timing compression ratio and such) are different for each application.
I look forward to following along. Not much going on with my project as winter has set in here in nj.
have a great weekend.
Mike
Rich11304
Hello Mike, Scott and Bamaman1
Welcome guys. You've already provided me with some good information. Once this boat is done, it will be kept on the side of my house on a trailer. I'm going to get very good at backing large boat in small space. I like the 360 idea. Deck height is a consideration. On the other hand, I might have found two 318 engines (210 hp) Rochester carbs pulled from a 28 ft Marinette in Tennessee, for 2k.
Rich11304
We're finished with the top upper side of the hull. I'm still debating about what to do. Have bottom sandblasted or take boat to a self-service marina like the Playboy Marina, block the boat and use paint remover/plastic for bottom as well. I'll try front bottom of the boat that I have access to and see and that works.
go with dry ice blasting or baking soda blasting and they can probably do it in your front yard.
