3.0 plugs
Mule Laker
Is there a known "best spark plug" for the 3 litre Mercruiser?
Is the NGK-BPR6EFS, box 3623 the standard? Any known issues or advantages with the Iridium UR6IX IX, box 7348?
Alumarine
My 1980'ish (566xxxx series) takes NGK BR6FS / 4323 @ .035? factory sticker says AC-R43T
Your's might be different depending on year/serial #.
Ayuh,..... Fancy shamcy spark plugs separate you from yer money, yer motor don't care,...
The AC Delcos are an Alloy body, 'n don't rust nearly as quickly as some,...
airshot
My boat is a 1983 and while it runs very well the compression is starting to get a bit on the low side so.......I used the A/C Delco plugs for a couple years without issue except for an occasional fouled plug, recommended to switch to the NGK plugs and have not had a fouled plug since. That was two seasons back so my boat will have NGK plugs this year. Just NO champions!!
wrench 3
Iridiam plugs were brought out to extent the life on automotive applications. Around here most marine plugs die from old age before they ware out.
