Re: 3.0l 120hp mercruiser to chevy 350 marine swap
He's a rev-head, and unless it can do 700 knots, he'll complain all day long... So let's help him get this madness out of his system.
Ok... First thing you are going to need to find out is if anyone else has done what you are
planning to do... If they have, find out how the extra weight and speed affected the boat. Did it try to chine-walk at speed, that's the main concern. If you are not experienced at handling boats at high speed, then a chine-walk will kill you...
For that engine in that boat I would recommend you have a serious look at changing the ratio not to 1.5 but to 1.32, mount the gimbal housing 2" to 4" above 'standard' installation height, and have through-hull water pick ups. Then start looking at surface piecing propellers, because you're going to be going way over the blow-out speed of most fully submerged props. You'll also need to look into either dual cable steering or the old 'rope' steering system, and you'll need to have a very close look at the gimbal ring-to-steering arm. They are notorious for getting wear in them and you'll end up with very sloppy steering. Not a good look at more than 40 knots!
I'd also look at trim tabs to control porpoising...
If you are going to change the gears in the drive, you are going to need the shimming tools. No, there is no other way of setting up the gear heights and backlash without them!
I hope you have deep pockets, 'cause this is all going to be very $pendy....
Chris.......
