crawdadric
- Nov 29, 2005
- 88
I am the third owner of this 1993 Bayliner Classic 19'. The engine is a Mercruiser 3.0L 181 cu 4 cylinder (S/N OD838683)with a Mercruiser Alpha 1 Gen 2 outdrive. I pulled the motor to repair a broken starter bolt and found several other areas that need attention. The exhaust manifold requires replacement, so I went searching on the internet. My original was bolted to the engine with three bolts and two studs with nuts. I found two types of manifolds, one with five bolt holes and one with six bolt holes. On the head there is six threaded holes (my thinking - six bolts would be better then 5 for sealing). I was wondering if I could use either manifold type. The carb is a MercCarb with one mixture screw.<br />Thank you.
