3.0L GM Mercruiser Engine Tap/Knock?
lilb
Re: 3.0L GM Mercruiser Engine Tap/Knock?
the best way i know of to tighten them is run engine with valve cover off and Slowly tighten the nut until is stops makeing noise> This way is a little messy at times but has always proved to be fool prof
dino941
Anyway I pulled off the two rocker arms and inspected the pushrods which seem to be slightly bent by a hair if that...
At this point why not take off side cover an inspect/replace them as they are like 3bucks each...
The tapping sound is up top and its is also down towards the lifters as well..
elcholopizon
Did you ever figure out where the knock came from? how did you fix it?
Thanks!
Carlos
