Re: 3.0L with Alpha One drive question
I'm not sure about your shifter problem, it sounds like it might not be engaged properly at the linkage. I would caution you that it sounds like you might be in for some false savings if you aren't careful. Bondo mentioned sending it to a shop - If all the gears aren't shimmed perfectly you've just wasted $400, not saved $1100. I just finished shimming a Volvo leg and it's a long process, and very precise. You can't just throw in a new gearset and drive away. Well, I guess you can drive away, but you won't drive back. From your posts it sounds like you don't have a manual and you might not realise just how important it is that the backlash is set perfectly. You can't do it properly without Merc's tools, either.
