Re: 3.7 170 hp mercruiser-Just quit and can't start.
			........How does a newer diaphram rupture??????
...been runnin' your problems through the ol' grey cells and this question keeps coming to the fore.
  Depending on which of the four or so pumps that were installed on the 470's, there was a spacer plate between the pump body and the mounting pad on the block.  (see manual #3, "Fuel Delivery", Sect. "A", Part "A", Diagram).
  Should a pump requiring the spacer be installed
without the spacer, I can see at least two things happening: (1) the pump will probably exceed the recommended 5-7 p.s.i. fuel pressure and (2), the diaphragm will over-extend and soon fail (rupture).
  Head on down to your local, friendly Mercruiser dealer and have the parts guy go through the micro-fitches to locate the correct pump for your year, horsepower and carb.  He can determine the requirement for a spacer, if needed.
