Watermann
- Jan 12, 2013
- 13,822
The rudder? Are you talking about the skeg below the LU gear case has been bent? Don't try to bend it back, most likely it will snap off. The skeg shouldn't effect your motors RPMS even if it were completely missing you wouldn't notice any effect unless you hit another rock that is. If your talking about the anode or trim tab above the prop then you can adjust that or just get rid of it for a flat model anode since you most likely have power steering and don't need the tab..
