Re: 30 psi compression in 1cyl what to do?
Here is the damage. Not sure what happened, looks like maybe a piece of a ring?? Needle bearing? Anyway, there is a hole in the piston. And the cylinder below it, has a bit of play in the piston to cylinder clearance, so I'm thinking a set of pistons and rings, and it'll be good to go. On the damaged cylinder there is a slight amount of aluminum transfer from the piston onto the cylinder, which I'm sure will clean up fine. Where is a good place to buy pistons?
