305 to 350 general engine questions
jopes
Got a few questions about going to a 350.
Do they use the same spark plugs? Same Gap?
Flat tappet to Roller cam. Do I need a new Distributor gear like in automotive engines?
Don S
Re: 305 to 350 general engine questions
Had a post all typed out, clicked the wrong button with a stray finger and lost it. Here goes aqain.
Keep the same vintage (year) engine, and most things will be the same. You need a service manual for what every year 305 you now have to find out what changes.
For oil questions, post over in the Non repair IO forum.
:D :D Ayuh,.... :D:D
They both use the same sparkplugs, Generally speakin'.......
'n as far as I know, the Distributer gear don't care what cam is in the block...
I've changed distributers between many motors, 'n never had a future issue with it's gear....
Generally speakin',... ;)
Ayuh,... Type with only 1, 'n ya don't have that problem,.... :rolleyes: :D
jopes
That must be a ford thing then. I know with a flat tappet cam in the ford engine they use a totally different gear material than the ones for the roller cams.
Thanks for the help!
dan t.
The steel roller cam requires a brass or a "melonised" steel distributor gear, the fuel pump pushrod must also be changed,once again a brass tip or a cast iron rod. I researched all this last year when I did a cam swap. Comp cams site has a lot of good info.
