newboater697
- Jul 30, 2008
- 23
Hey guys,
So this is what i've done so far. Took the boat on a trip and when we got back the primer bulb would not get hard. Took apart the motor to get to the carb. Found a small piece of metal in the bowl, float still floated, needle was in the seat. I put it all back together. Took it out and had trouble keeping it going on low speed but eventually got it going and the motor ran ok in higher speeds. Took it back to the dock to adjust the low speed rich/lean screw and it was running better. Shut it off and hasn't started since. Primer bulb is getting hard, seems to have spark, fuel lines are good... getting tired of trying to pull start it and getting tired of the blisters i'm getting too! Anyone have any ideas?
Also, at one point I thought i was going to have to take the flywheel off so I took the edge bolts off but not the big brass bolt on the very top. The flywheel did drop but luckily I didn't have the right tools to take the top bolt off. I put the flywheel back on but could I have thrown off the timing? I got a book from the library but it doesn't show any timing marks for the 33hp and I couldn't see anything except on the top it says 0.020. Any ideas?
