Re: 33hp evinrude tachometer
Hello Tommy.<br />Connect 12V +/- to the tach, and the pulse terminal on the tach, shall be connected to your rectifirers primary side.<br />You can use diff. kind of tach. as long the settings on the back side of the tach is correct. If you find a tach, where there are settings for 2,3,4,5 and 6 pol. the set the setting at 4 (your motor have 4 pole)
