35 hp evinrude
patrick4266
I am thinking of buying a 35 hp rude model number 35752H. Can any one tell me what year that is? Also he says it runs but has low compression on one cylinder. Is that more than likely a head gasket or bad rings?
tashasdaddy
Re: 35 hp evinrude
it's a 1977 possible head gasket, or rings, you never know till the head is pulled. if only a slight difference in readings, you can try a decarb before tearing it down, this may free up the rings. here's the proper manuals
"http://www.outboardbooks.com/index.cfm?fuseaction=models.main&year=1977&ID=52381"
F_R
Re: 35 hp evinrude
Is the paint discolored from overheating? The 1976 would overheat if it got anywhere near weeds. Then for 1977 they changed the water intake a bit and they were some better. But they didn't really get it fixed till 1980 when they moved the intake to the sides of the gearcase.
