Unloaded my Rinker 232 from the trailer, idled a bit with no issues (10 min MAX.) while I waited for my buddies to arrive, and headed out and within 1 minute of cruising at 3200 RPM, the boat slowed down quick and bogged out, as if I throttled down back to neutral. Tried to restart it and got nothing. Got towed in and brought the boat back home. Trying to start on the trailer, I can see puffs of black smoke coming out of the exhaust as if to say its flooding and no spark to fire the motor. I have VesselView on the boat and it is not throwing any codes or no alarms, all temps and PSI were normal. I haven't been able to check for spark yet, but what should I be looking at? VesselView reads RPMs while cranking, so I'm assuming the crank sensor is good. Does the 350 Mag have a CAM sensor? I will be checking for spark in the morning, but what is the best way to go about doing that? I'm used to smaller motors and usually ground the plug on the head and attempt to start it. Lastly, the fuel pump does kick on, and I changed the fuel/water separator because i had a spare and it checked out good. Because the pump is kicking on I think it is safe to eliminate Neutral Safety and Lanyard Kill Switch, but please correct me if I am wrong.
