silver_power
- Jul 8, 2009
- 327
Hello, my 2009 350 mag mpi (1A348183) alpha one genii drive, running hot when it is on idle. To be more specific: when running cruise and wot the temp is steady 71-73 degrees C (160-165F) but when returning at the dock and idles the temp raises till 85-88C (185-190F) not more. If I push the throttle to 1000rpm, the temp drops. Manifolds-raisers - impeller new. The thermostat was changed 1 year before as then was the first time the engine overheated but the reason wa's the blocked manifolds. The mechanic then gave me a 75c tstat instead of 71c which is the standard rating for my engine. So now I have 75c tstat. Is it possible that this is my problem?....meaning that the engine runs hotter and when it dles, the low water supply of the alpha drive at idle can not cool down the engine fast?
