silver_power
- Jul 8, 2009
- 327
Hello. My engine is a 2009 350 mag mpi (s/N 1A348183) with about 400 operation hours..Last year I had the known problem of corroded risers and water entered to the starboard side of the engine. I pull off the engine and it did not crank. Finally the 2 cylinders had rust and the engine did not crank. The other side was OK. So I fixed the engine,. Did a compression test with very good results and before put the engine to the boat, we did a scanning check and everything was good ( cylinder test, no fault codes, no missfires, no knocks etc). So i put the engine to the boat but i have two issues.
1.the engine starts but it does not crank as it used to crank. During cranking, it spins nice for a little, after slows down, after spins good again and it starts nice with no throtle. The batteries and wires are new. I tried new starter, but same results.
2. The other issue concerns the consuption
I have smartcraft gauges and I see that the mpg reading has changed. For example at 2800rpm the boat normally runs 3.4-3.7 mpg but this year runs about 2.8-3.0mpg. It consumes about 15% more gas with the same conditions and load. During docking I can smell some gas as well. The idle is smooth and the rpm at wot is normal about 4900-4950rpm just like always. I had no plan to check it at wot but i suspected that maybe there is no fire to a cylinder and that is why it runs rich and have the smell of gd.So i check it and the results at top end were the same as always.I Must tell that i have no beeps at smartcraft. The temp reading is perfect about 158-162oF. Is there a possibility that it runs rich because of the repair of the block and it must operate for some hours?
Do you have any ideas about these 2 issues I have.
Thank you very much.
