350 mercruser wont start in water.
wez1585
hi guys i have been beating my self for a little bit on this prob. and i cant figure out why i can start the 350 1985 mercruser with a 4 b rochester carb in the water. i can start it all day long on a hose. just a couple turns. but when i go to the water it turns and turns but no start. if i pull the bout out a little bit just enogh to have the water pick up under water it will start and then ill back it down all the way and it will idle for a little and then die down and will not restart. i have changed filters water separator and inline at carb inlet. i am lost
thanks guys.
Alpheus
Re: 350 mercruser wont start in water.
Is the boat not starting when the bow is up in the air as if on a boat ramp?
Is the drive in a different position on your trailer (when its running normal) than it is when in the water?
I would check out why its not starting in the water. lack of fuel or spark. It sounds like a fuel problem to me. Is
Don S
Do you have the timing set to specs? Not bv ear, by using a timing light and actually makeing sure it's at the proper degrees.
wez1585
it dosent start when is fully trimed down and the boat is floating in the water. and about the timing i havent really checked that.. ill check timing tomorrow do tou have any idea what degree is suposed to be?
Don S
8? BTDC at 700 rpm.
wez1585
ok i have tryed before to get the rpm to around 700-750 at idle but when i get it below 1000 it idles for a few secs and then bogs down could that be a sign of out of timing?
Nope,... It's a sign that the Carb is All Boogered up...
