jimmbo
- May 24, 2004
- 14,132
While the 18/20 hp shared the same displacement as the 25 in 69, they had different Pistons, Crankshafts, Carb, and as you know Cylinder Heads, The 25 Head has a smaller Combustion Chamber, to restore the Compression that the 25's Pistons reduced. Putting a 20hp Head on a 25 will really drop the Compression, might be fine if you want to run it on Kerosene, but there will be a real drop in power
