Re: 4.3 Gi won't idle
Code from the back.
Everything is origional except the block/heads. I have replaced the iac, map, tps, injectors, alternator, raw water pump, oil sending unit. It just got a tune-up and a fly wheel after I found out when the origional owner overheated it, he tried to start it and removed half the teeth for four inches.
Code from the back.
