Re: 4.3 l mercruiser wont shift out of foward gear
If it is an Alpha I: If the control moves freely back and forth, WOT F to WOT R then the washer is missing. If the control james when you pull it back, then the gearhousing was in reverse rather than forward when you put it back together and the intermediat shift shaft went onto the lower ss off a spline. Shift to WOT F. Drop the gear housing, rotate the lower ss (short splined shaft) all the way clockwise, rotate the prop counterclockwise till it locks and use a bungee th hold it in place, you are now in forward. Put er back together making sure the bottom of the upper ss and the top of the intermediate ss both point straight forward. Should be good to go.
