It's been a week since my last update. A lot has both changed and been accomplished since then. To start, I received my donor vehicle last Thursday. It is a 2000 Jimmy. I was planning to pull the motor and scrap the vehicle. However, it is in such good shape that I have decided to keep the Jimmy (it will replace my Silverado). the Jimmy needs brakes and maybe wheel bearings, but otherwise it is a cream puff. Consequently, I bought another motor from a scrap yard. It is out of a '97 Astro.
I have nearly finished the swap. Here are some of the notes I've made. Keep in mind that my Mercruiser is a 2001, and the replacement is a 97 GM truck engine.
Oil Pan and pump
Marine and auto pan are different. Auto pan is actually deeper, and subsequently has a longer pickup. Oil pumps are the same (#GL214). I swapped the mercruiser pan onto the Astro engine with the pickup as well (it is a press fit pick up).
Motor Mounts
Motor mounts are in the same location with same triangular bolt pattern, however my 'marine' 2001 block used 7/16" bolts whereas the Astro motor uses 3/8" bolts. Perhaps this was a change made by GM between '97 and '01.
Flywheel
Astro motor uses a much lighter flywheel. I swapped the flywheel from the marine motor to the astro replacement motor.
Freeze Plugs (core plugs, expansion plugs, whatever you want to call them)
Marine engine is brass, Astro is steel.
And then of course are the accessories. I swapped all the Mercruiser gear onto the Astro motor. I read somewhere that Mercruiser waterpumps have a different (steel?) impeller, but I did not verify this, or even look at the part numbers (I suppose I could). Starter, distributor, alternator, water pump, brackets, engine harness etc came off the Mercruiser and onto the Astro.
