wire2
- Jun 25, 2007
- 1,584
Re: 4.3 Merc oil leak on top of intake
The heads get oil pumped up through the lifters, push rods and spit out by the rockers. It drains through small openings in the head casting, usually front & rear. The drain holes have to line up with a hole in the head gasket, and then drains down a return hole in the block. There's probably 2 drain holes on each side in a SBC, front & rear, and the oil will tend to trickle down the casting, not onto the crank.
I'm thinking it's more likely that oil is being thrown from the crank con rod journals, which are under pressure. All 8 con rods are directly in line with a cylinder, so lots of small drops being flung up at TDC of each piston.
Anyone?
Ok, that may be the case, but I'm dubious that it's coming from the top of the engine.Yes, the cylinder walls and cam lobes get oiled by the counter weights slinging oil, but it's not from running in oil in the pan. It's slinging oil that's draining back from the top of the motor.
Anyone?
