4.3 mercruiser alpha 1
nola mike
I have a really dumb question… the plug I drained was a brass plug down by the oil filter on the lower right side of the motor… that IS the oil plug right? I can send a picture tomorrow.
Nope, not oil plug. I mean, did any oil come out?
No. That would be the water jacket.
Oil is sucked up with a pump up your dipstick
alldodge
You can try a break it free with oil but probably best pull the motor.
Could also remove intake and heads to see what it looks like inside
Scott06
Before you jank engine I would try pulling the drive to ensure that the drive, gimbal or u joints aren't locked up. Then use a strap wrench on balancer so you don't risk breaking the balancer bolt off in the crank.
Jvanlue
Ok here’s where I’m at. I pumped all the old oil out of the motor. There was no water in the oil. I squirted as much marvel mystery oil into the cylinders as I could. Then I put the rest of the oil in through the dipstick. I pulled the drive off. I’m attaching pictures. When I pulled the drive off, oil came out. Not sure if that’s normal or not…
Jvanlue
Motor still won’t crank, I can turn it with a socket and breaker bar…. But the pulley wheel doesn’t move
dubs283
Oil in the bellows is most likely gear lube from the drive. Guessing yoke seal failure.
Drain and pressure test the drive to confirm.
Safety wire is not installed correctly on the shift slide
What is a pulley wheel?
alldodge
What do you think is most likely wrong, cracked block?
The motor is seized. It may not be cracked, but from what you have provided so far there is a deficiency in knowing what needs to be done and path forward. So the easy route is new/rebuilt long block
Can disassemble the motor and rebuild, or get another. Could get a short block (no heads) and gets yours rebuilt or do the pains taking of freeing up yours and then having a machine shop rebuild
Jvanlue
I put a new starter on but didn’t include the spacer that came with it. Is there any chance the new starter isn’t lining up? What if I pull the new starter and try spinning the flywheel by hand?
nola mike
What/how exactly are you turning? Are you telling about the balancer on the front not moving?
Jvanlue
Further diagnosing today. Pulled the starter off, it spins, tried moving the flywheel with a screwdriver, no dice.
Pulled the carb off… lots of rust picture attached
Pulled one of the risers off, no rust pictures attached
Pulled a valve over off, cylinder heads don’t look bad. Still have oil but does look a little white/frothy picture attached
I’m guessing by the amount of rust on the intake and on the spark plugs, the cylinders are rusted pretty bad
dubs283
Perhaps
But, keep posting pictures and descriptions of vain attempts to unseize the engine. It may help
I'd have stopped pretending a while ago but someone here may have the right solution save from purchasing a rebuilt long block
dave8311
You need a breaker bar on the front end of the crank to turn the motor over, but not using the bolt that holds the pully/balancer on. It will break off in the end of the crankshaft, and now you are surely done.
There are a couple of different options for using a breaker bar, use the one you like best.
Just google "crank turning tool"
