4.3 mercruiser not starting
usafracer
My 1999 chaparal just started this probablem when trying to start it for the first time this season. It has a 4.3 mercruiser!!Engine turns but willnt start. When i try to turn it over the fuel pump doesnt come on and im not getting any spark. I am not getting voltage to the coil with the ignition in the on position. i have no idea where to start. I dont even know if there are fuses or where they are?? someone please help!!Also no power at the coil? sorry for the repost, i wanted to changed the title
Coors
Re: 4.3 mercruiser not starting
It sounds like a wiring harness connector, for all to not work. start cleaning and greasing the main connectors. Then with your volt meter, start from the ignition switch, and trace the wires to the engine, for voltage. I found some look-good-to-me connections that were'nt, after 3 months, of sitting, last month.
Don S
Is this an EFI engine? If it's a carbed engine, you won't hear the pump run before starting. It only comes on during cranking, and you couldn't hear it if you wanted to.
No spark is a different thing. The safety kill switch is on .......... isn't it??
If it is, start from the ignition switch and follow the purple wire to the engine and find out where the voltage stops.
Don S
Is it EFI or Carbed?
The kill switch is the one with the lanyard you attach to yourself incase you fall overboard.
